Help installing angel eyes..
- Bike owned: NC35
Well my LED strips arrived today, all i need help with is how do i wire them to my system to get them working?
- Bike owned: NC35
Re: Help installing angel eyes..
i'm guessing you don't have a haynes manual...otherwise you could follow the wiring diagram
i'm gonna go out on a limb here and say the negative wire on the LEDs should go to ground and positive go to ignition (not to battery, otherwise the angel eyes will be constantly on)...sure someone will correct me if i'm wrong, can't remember the wire colours off the top of my head sorry.
or just wire them to the side light circuit/wiring so they only on when the side lights are on? that way they can be on or off. do bare in mind that the heat of the H4 bulb will eventually knacker the LED'sludacris wrote:i'm guessing you don't have a haynes manual...otherwise you could follow the wiring diagram
WTF are angel eyes?
- hallsie
- Bike owned: NC29
Headlights as you see on a beemer with the rings around the main lightsDrunkn Munky wrote:WTF are angel eyes?
kate beckinsale....... mmmmmmm
- Bike owned: NC30,
There was a thread in the cbr section recently, might help:
viewtopic.php?f=28&t=19930&p=137536&hil ... es#p137536
- Bike owned: NC35
hmmm...wouldn't that mean that his angel eyes will be intermittent with the side light? not really the desired result...porndoguk wrote:or just wire them to the side light circuit/wiring so they only on when the side lights are on? that way they can be on or off. do bare in mind that the heat of the H4 bulb will eventually knacker the LED'sludacris wrote:i'm guessing you don't have a haynes manual...otherwise you could follow the wiring diagram
if porndog's way works without flashing with the side lamps then that's an option along with what i suggested earlier..other option is to wire them to the low beams so they switch off when hi beams are in use and last option would be to use an on/off switch in the circuitry if you want personal control using the ground & ignition power method i mentioned before
i would highly suggest you get your hands on a wiring diagram bud
The side lights operate with the headlights, we don't use them in Oz (against regulations?), they're the bulbs in teh bottom of each headlight.ludacris wrote:hmmm...wouldn't that mean that his angel eyes will be intermittent with the side light? not really the desired result...
ludacris wrote:i would highly suggest you get your hands on a wiring diagram bud
- Bike owned: NC35
aaaahh i see..learn sumthin new about these things everydayCammo wrote:The side lights operate with the headlights, we don't use them in Oz (against regulations?), they're the bulbs in teh bottom of each headlight.
