Carb testing?
- Smev
- Bike owned: NC30 of course
Carb testing?
Just wondering if there is a way of testing the carbs are all sealed correctly before fitting them to the bike?
Last time I tried fitting them, it took me a while to get them on the engine, then the tank and hoses connected up. Turned it over, and the bleedin' thing were p*%$ing fuel all over the place
So to save all that hassle, can i test them before?
Cheers Smev.
Cheers Smev.
Mister Donut Rep NC30
Re: Carb testing?
Fill them with petrol??
- Smev
Re: Carb testing?
It was the float bowls which seemed to be leaking - not sure how to get them to fill up properly - would just funnel into the pipes work?
- ibby4585
- Bike owned: SP's
Re: Carb testing?
Syringe Fuel into the main fuel line is what I do just to check the float bowl gaskets.
Kris
Kris
hunter
Re: Carb testing?
the best way to do this is to get a small tank,
lawn mower,moped,hang it from the workshop ceiling,
grt a couple of mtrs of fuel line,one inline fuel tap,
you can do all the testing you want.
- Smev
Re: Carb testing?
Thanks guys - good ideas there!
For some reason I was thinking it was pressurised, - thinking about it, its obviously not!
