skinnydog0_0
- Bike owned: Penny Farthing
Post
by skinnydog0_0 » Thu Jan 27, 2011 7:36 pm
Hi all,
What carb balancers do you folks use?
I am weighing up wether or not i should get some or just wait till i get to the dyno
thunderace
- Bike owned: R6, YZF600R
Post
by thunderace » Thu Jan 27, 2011 7:57 pm
I use these and they're pretty darned good.
I've never experienced the so-called damping issues other poeple report when using this type of gauge
skinnydog0_0
Post
by skinnydog0_0 » Thu Jan 27, 2011 8:31 pm
Cheers guys
Gonzo, did your erratic tick over get sorted after the plug change?
Mine is sort of doing the same, and i have a feeling it is teh plugs, after i had some other starting issues and flodded it a few times. I have a feeling one or more of teh plugs is on its way out.
I reckon it's time to change them and see. cheaper than getting a carb balancer and finding i need plugs to sort the problem
Variablevalves suck
Post
by Variablevalves suck » Thu Jan 27, 2011 10:20 pm
You can use mine, not a problem to post them over.
skinnydog0_0
Post
by skinnydog0_0 » Thu Jan 27, 2011 10:39 pm
Variablevalves suck wrote:You can use mine, not a problem to post them over.
Cheers buddy much appreciated
PM Sent
gonzothegreat
Post
by gonzothegreat » Fri Jan 28, 2011 4:21 pm
I haven't changed the plugs yet, the intake rubbers were dodgy (old and cracked).
Still waiting to install the NC35 carbs, will be done this week-end.
arsey30
- Bike owned: ftr223 650 bros
Post
by arsey30 » Fri Jan 28, 2011 5:17 pm
thunderace wrote:I use these and they're pretty darned good.
The white nylon damper valve can be adjusted to give a steady reading.
For some reason mine go out of calibration between each use.
Now I always check and calibrate if needed.
Connect each gauge in turn to number 3 cylinder and adjust dial so each gauge reads the same.
Dave.
slowsport
- Bike owned: NC35
Post
by slowsport » Fri Jan 28, 2011 8:56 pm
i also use carbtune, which ever one you get try and invest in a 90 degree angled screwdriver for easier access to the tuning screws underneth.
skinnydog0_0
Post
by skinnydog0_0 » Fri Jan 28, 2011 9:08 pm
Cheers for the advice guys, much appreciated. VariableValvessuck, has very kindly offerd to lend me his
I will get the carbs set as best i can, and as it's going on teh dyno at the end of next month, i will get it fully sorted then. I think i might buy some in the future, but at the moment i have shed loads of other stuff to get first (now i have a set to use).
Thanks again
