R&G non drilling crash bungs
Spike16
Post by Spike16 »
thinking about getting some to protect my newly painted fairings when they get back,
are they easy to fit?
anyone used them in anger?
pictures verry welcome
o and what opinion on the colour to go for with this scheme (black or white)
viper_biker
Re: R&G non drilling crash bungs
Post by viper_biker »
I have white ones fitted to my bike,
Psychosomatic88
Post by Psychosomatic88 »
+1
MUST be white
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
Spike16
Post by Spike16 »
kl, do you have to remove the radiator to fit the bungs? as iv just fitted them adn that would be annoying :roll:
I thought black would look better becase it would be less noticable from a side on view, i think i need more pic's to make a decision ;)
viper_biker
It can be done with the rads in situ but those pics are from when I was doing a strip, clean and re-build. I have lots of pics with the white bungs if it's any help to you.
Spike16
Post by Spike16 »
ok thats good, have you got any side on flat silouette type photo's, that would be best to compare to the black bungs, also how far do the bungs stick out the fairing aprox?
viper_biker
Any use?
fastdruid
Regular Member
Post by fastdruid »
Ok they are a bit of an arse to use as you have to remove them every time you want to take the fairings off but they do a good job.
My wife threw her NC35 down the track at cadwell last year
http://www.fastdruid.pwp.blueyonder.co. ... _short.wmv" onclick="window.open(this.href);return false;
As you can see from this picture although it damaged and bent the crash bung it left the fairing mainly unmarked there was a slight bit of damage where the crash bung bent back to touch the fairing.
I damaged the fairing getting it off but that was because I was at the trackside, if I'd had been at home I would have cut it off and saved further damage.
It still took out the gear lever, clutch lever, bar weight and damaged the exhaust (the standard wire shield would have prevented this though).
Unfortunatly in this case when it got to the edge of the track it flipped over[1] but that's not the fault or anything the crash bungs could have done to save it as I think it just sank into the earth on that side!
Druid
[1] Broke brake lever, bar, indicator, footpeg, bent subframe, cracked fairing and cracked seat unit.
