nc23 speed restrictor question
Posted: Sun Jan 23, 2011 2:15 pm
by jurassicreps
hi, im removing the speedo on my track bike so the speed restrictor wires wont be connected. is this a problem? i would like to put a gold ecu on it anyway really but not right now. or is there any other way to remove the restrictor?
Re: nc23 speed restrictor question
Posted: Sun Jan 23, 2011 6:27 pm
by thunderace
Having it unplugged won't affect the bike. All it does is make a connection when the needle goes past ***kph. If the connection isn't there to make, it won't restrict the bike.
Posted: Mon Jan 24, 2011 9:48 pm
by jurassicreps
thunderace wrote:Having it unplugged won't affect the bike. All it does is make a connection when the needle goes past ***kph. If the connection isn't there to make, it won't restrict the bike.
really????? if that was the case then why do people bother cutting the speedo disc or soldering a resistor into the wire when they could just cut the wire and the restriction is gone??
Posted: Mon Jan 24, 2011 11:17 pm
by Cammo
jurassicreps wrote:really????? if that was the case then why do people bother cutting the speedo disc or soldering a resistor into the wire when they could just cut the wire and the restriction is gone??
On nc30's when the speedo unit is removed (or the wire is cut) it cuts spark to 2 cylinders after 5000 rpm. I imagine the nc23's have a similar setup being from the same era??
You can get around it on nc30's the same way as bypassing the 180 km/h speed restriction (install resistor in correct wire etc).
Posted: Tue Jan 25, 2011 9:11 pm
by hallsie
This is the case on the nc29's , the bike will cut to two cylinders unless you cut down the disc
Posted: Wed Jan 26, 2011 12:45 am
by Wozza
Are you removing just the speedo or the whole clock unit?
Posted: Thu Jan 27, 2011 10:08 am
by jurassicreps
Just removing the speedo. The rev counter and temp gauge are staying put
Posted: Fri Jan 28, 2011 6:52 am
by superlite
