Cbr 1000 fireblade 2008-2010 mirrors on rvf 400
code2006
Post by code2006 »
Hi does anyone know if a set of cbr 1000 mirrors with indicators will fit my nc35?
Thanks Alex
Ps I will be back on here more often again coz I will be continuing my ref project :d
ludacris
Bike owned: NC35
Re: Cbr 1000 fireblade 2008-2010 mirrors on rvf 400
Post by ludacris »
you will need custom mirror bases for side mount unless you plan on top mounting them...
code2006
Post by code2006 »
ludacris wrote:you will need custom mirror bases for side mount unless you plan on top mounting them...
Well my plan is to replace my STD ones with the cbr 1000 ones but i dont know what the distance is between the two bolts on them mirrors to compare with the holes on the fairings
ludacris
Bike owned: NC35
Post by ludacris »
well not knowing the exact distance...i'd say it's most likely to be 40-45mm spacing compared to the 30mm spacing of the RVF...if the indicators are also LED then you will need resistors in the wiring or an electronic flasher relay
i'd say you're best bet is to get on the fireblades.org or 1000rr.net forums and ask for the exact bolt distance...maybe someone else on here might know..
code2006
Post by code2006 »
ludacris wrote:well not knowing the exact distance...i'd say it's most likely to be 40-45mm spacing compared to the 30mm spacing of the RVF...if the indicators are also LED then you will need resistors in the wiring or an electronic flasher relay
I think they have normal bulbs in them but I have already wired in resistors for led bulbs for front and back
