Widest tyre to fit a NC35 rim
andreasmkr
- Bike owned: Honda NC35 RLR Stage III 94'
What would be the widest tyre you could fit a NC35 rim?
Cheers,
Andreas K
Cheers,
Andreas K
Re: Widest tyre to fit a NC35 rim
160/60
It is a 4.5 inch rim...any wider and you'll be rubbing the chain and make it handle shit..
andreasmkr
Thank you
Any tyres you would recommend for road use?
- BillingCBR
for 400's probably the most accepted option is the Bridgestone BT090, but I've heard good things about Conti Road/Sport Attacks, mate had a set on his CBR6, lasted forever, and when he had it on a track said they were very good for warming up fast and giving good grip :)
- royster81
I've seen a 180/55 on the back of an rvf but I wouldn't recommend it, 160/60 is plenty and I run super corsa pro's but only when it's dry......
surfer 69-b
i had michelin pilot power tyre on the rvf and liked them better than the 090
- Cru Jones
- Bike owned: NC35
So, is the consensus that if you run a 160/60 you need to also run 520 chain/sprockets?
- skinnydog0_0
- Bike owned: Penny Farthing
Same topic but slightly different sorry
I have noticed that dunlop have a wet rear thats a 165. Do you reckon this would fit? The 160 i have is pretty close to the chain already.
Also am i right in thinking that the difference between a 160 and a 165 is 5mm? making 2.5mm extra width each side?
arsey30
- Bike owned: ftr223 650 bros
Yes and no.skinnydog0_0 wrote: am i right in thinking that the difference between a 160 and a 165 is 5mm? making 2.5mm extra width each side?
They are nominal dimensions, my 180s are 178mm [super corsa pro] and 182mm [hi sport] .
A friend used 2 of the same type Bridgestones a while ago and found different batch/tyre moulds were a few mm different in widths,
Dave.
skinnydog0_0 wrote:Same topic but slightly different sorry![]()
165 will fit for wets - the Oz massive run 165 slicks so get them sorted.
