restictor dims needed for cb1 400 1989
hi there all i'm looking for the dimentshions of the resticting washers for my cb1. any help would be really helpful
meany thanks
craig
meany thanks
craig
- Bike owned: CB-1, MSX125
Re: restictor dims needed for cb1 400 1989
These are the dims of the set I had on my first CB-1 years ago.
I have recently bought another CB-1 and it rides suspiciously like it might be restricted. I will investigate this weekend, I may have a set of washers to sell you.
Sorry, turns out my CB-1 isn't restricted, just a bit slower than the old one (37 tooth rear cog)amorti wrote:
thanks mate thats a grate help relly apreashetated
craig
craig
hi there the dims dnt add add up as the 3mm hole in the washer doses not fit on the washer when i have drow them up. do you have any idea where i have gone rong
It's "just" a 35mm washer with a 17.4mm hole in the middle. If you are going for the dyno-proof option, I would leave the extra hole off. If you dyno it and it makes 29 then leave it, if it makes 25 then add a little hole about that size. I don't understand how the hole would "not fit" to be honest as that's a 3mm hole in a 8.7mm wide "ring", so it deffo should fit.craigttay wrote:hi there the dims dnt add add up as the 3mm hole in the washer doses not fit on the washer when i have drow them up. do you have any idea where i have gone rong
My drawing is more or less to scale, if yours looks different then you have misunderstood my notation.
