NC 35 not firing on rear cylinders again
I have stripped carbs again to find dirt in rear 2 carbs again!!!
I have now emptied all the fuel in the tanks(lots of dirt in there). I removed petrol tap and the filter is in there but not great condition, but no holes. I have stripped the carbs completely and gonna ultrasonically clean them. I intend to put a filter in the fuel line. Has any body any suggestion as to best filter to use ?
Re: NC 35 not firing on rear cylinders again
small cheap ones, as there just isnt the room to put a decent big one in
there are filters on the float valve bases, and on the tank its self so as a rule filters arent particually needed.
http://cgi.ebay.co.uk/Fuel-Filter-7mm-/ ... 588be02574
- uber pikey
Hi, I know a lot of people on here will tell you not to use the cheap plastic see through type filters but I have one fitted to mine
, not only can you see if the fuel has stopped flowing due to vacuum problems
but it stops my fuel pipe from kinking when I secure the tank down
and you will see if there's shit coming through from your tank again.
I saw it so I took it!
uber pikey wrote:Hi, I know a lot of people on here will tell you not to use the cheap plastic see through type filters but I have one fitted to mine, not only can you see if the fuel has stopped flowing due to vacuum problems
- Trinirides
- Bike owned: NC30 is all you need to know
Why????
I have had these fitted to my old off roaders for years they never gave any issues..
found this one will tuck in nicely 8mm is that ok ?porndoguk wrote:small cheap ones, as there just isnt the room to put a decent big one in
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Finally got to the bottom !!!! The dirt getting into carbs is comming from the tank. I took petrol tap off a rinsed the tank with petrol and bunged hole. When I emptied the petrol into a bowl lost of fine particles of rust. I did this about four times to clear tank, and have now also put filter in line. I hope this will be the end of all the hassle I have had !!!
Anybody who has this misfire on rear cylinders should do this before they put tank back on!!!
Many thanks to all that helped !!! and still have ultrasoic cleaner which done the trick too !!
- Bike owned: NC35
What type of ultrasonic cleaner do you have and how big is it?
Its one off ebay 300X100X100 with heating control split carbs onto 2 and they fit in.amaechizzle wrote:What type of ultrasonic cleaner do you have and how big is it?
Works a treat.
