Howto: K&N Filter for NC30
after months of trial and error between myself, other forum members, and K&N the company its self. we finally have a solution with a reasonable price tag!
A close to perfect fit K&N panel filter - Product Number 33-2006
it cost £28.99 (2010) NOW £28.66 (2012)
http://www.ebay.co.uk/itm/DODGE-Charger ... 46063c58d7
http://cgi.ebay.co.uk/K-N-AIR-FILTER-33 ... 45f0e514b9
http://www.knfilters.com/search/product ... od=33-2006
Tools Needed:
Stanley Knife,
Chissel (Sharp - Wood)
Sand Paper,
1. Remove the Paper filter close to the houseing with your stanley knife, easy peasy job.
2. remove the filter gauze from the under side, there are 6 abs plastic blobs/lugs, i found a sharp chisel easiest and gave it a sharp tap to cut the heads of. a stanley knife would do it but due to working within the housing it may be tricky.
3. cut either the right or left hand shoulder from the filter, ONLY CUT OFF/REMOVE ONE SIDE i used my stanley several times just score the surface and go over it 10 times and the knife will drop through the plastic is very soft so dont force it, just take your time.
(i cut the LEFT hand side,) this pic is upside down btw.
4.remove the remainder of filter paper around the houseing with a "SHARP "chisel, and then sand off the excess to remove any chance of break down entering the engine/fueling system.
5. then fit to bike, and have a beer.
Finished Article
Bellow
Fitted 1
Through the Snorkle
Tools Needed:
Stanley Knife,
Sand Paper,
Finished Article
Bellow
Fitted 1
Through the Snorkle
Re: Howto: K&N Filter for NC30
also
the standard paper filter is 20mm deep with 43 Fins from left to right
the K&N cotton filter is 28mm deep with 15 fins from front to back
so far more surface area for air to pass than before.
- ibby4585
- Bike owned: SP's
Well done Ricky! Nice sticky that!
Kris
Kris
ive been itching to tell everyone for weeks, but i wanted to make sure it was a surething before letting everyone know. i was the guinea pig and didnt want everyone buying one and it not fitting.ibby4585 wrote:Well done Ricky! Nice sticky that!
Kris
chuffed it fits etc, just hope it cures my mid range flat spot, or over compensate and make the bike run lean, if so up a size on jets wont be riding or starting for month as i still have loads to do!
- ibby4585
- Bike owned: SP's
Let us know how it goes and mods you do to the carbs I may do it to both my bikes!
Karma points for you sir!
Kris
Kris
Thanks for the karma kris. what a gentleman you are.ibby4585 wrote:Let us know how it goes and mods you do to the carbs I may do it to both my bikes!
Kris
Alex witham will the test pilot, as i dont have a rear end to the bike at the min! hes ordering and planing on dynoing early in jan so will be a good start to see where its at, my bike is gonna be ace to ride when back together QA throttle, new air filter, powder coating everywhere, upgraded rear shock, its going to be like a different/new bike to ride.
just for bumping purposes and a little update on this.
after modifying the plastic air filter base plate, 2 x 25mm dia holes and then dremmelled the bits out between i have a small opening to clean cold air.
also i finally start the bike on saturday just gone.
and can confirm that it revs much better through the midrange, more better throttle responce for sure as compared to the old one, i will get this confirm on the dyno. i have spoken with rick oliver aboiut this a couple of times and he's all in favour for everything ive done, the hole the filter etc and confirms it would be better than stock, and a better upgrade to that of an exhaust.
ill be hopfully taking the bike for a spin on saturday and i shall report back.
- banoffee
nice one! I sealed mine with some black sealant to be on the safe side.
- ibby4585
- Bike owned: SP's
Wherabouts did you make the opening in the baseplate?
Kris
Kris
- banoffee
not sure it that's aimed at me or not. if it is, I didn't, PDQ made mine (I bought it second hand)ibby4585 wrote:Wherabouts did you make the opening in the baseplate?
Kris
