NC24 - Fitting the Hornet 600 Shock.
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Decided to play with my new shock this morning, a Showa unit from a Hornet.
Got the old shock off no problem.
Old and New
Not quite the direct fit I was hoping for :cry:
Due to the extra length of 13mm and the extra diameter of 6mm, the bottom dog leg mount needs a larger offset and I need longer bones :twisted:
I need to increase the offset by about 13mm from the OE 45mm
And increase the dog bone length by about 15mm from the standard 100mm
Does anyone know of anything that will fit before I start making things?
Cammo
Re: NC24 - Fitting the Hornet 600 Shock.
Post by Cammo »
I think modifying this lot to fit the hornet shock will possibly ruin the handling of the bike.
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
Seems like a lot of work for a shock that may not work well - but I appreciate that someone has to do the leg work :up:
How much longer is the Hornet shock? Assuming that the linkage works in a similar fashion to NC30/35, lengthening the linkage will defeat the purpose of installing a longer shock. i.e no increase in ride height. If the linkage ratio is in the same ballpark as NC30/35 (which it probably isn't), then you'd be loosing about 45 mm of ride height and then adding what looks like about the same when you fit the new shock. I agree that it will probably bugger the handling. But I'd be pleased if you proved me wrong ;)
'Take it to the Back'
