Braking 1992 GSXR 400 GK76A
GIXXER_PILOT
This is a copy of my old post which didnt get much chance as it was posted close to the blocking of the old forum. Some parts i have been asked about so please bear with me for replies.
all parts avaliable (bike is complete at this minute)
I will probably miss a lot of parts but these are the parts off the top of my head. I have so many more little bits here and there so if there is anything your looking for email halil.ahmet@hotmail.co.uk I havereciepts for around 2K worth of parts im trying to clear as well as the bike
USED PARTS:
Both yokes
Frame with V5
swingarm
Wheels stripped and sand blasted
1 tanks in standard colours no damage
OEM fairing panels no damage at all but diffrent colours as was going to be sprayed.
standard shock+rf900 shock
tokico 6 pot calipers
clocks also have a mph clock from an rgv 250
steering damper freshly rebuilt with fitting kit and instructions
air scoops and pipes
rearsets
pillion hangers
both seats
SOLO SEAT COVER
Cutch lever assembly
Master cylinder with rebuild kit fitted (59600-45860 rebuild kit
SOME NEW PARTS:
suzuki oil filter (16510-06B01)
cooling pipe 17856-33C0 (the one on the left hand side with the bleed screw)
Air filter OEM NEW
Clutch cable OEM NEW
Sprocket shaft seal 09283-30044 OEM
rear indicator mounting circles (1 for each indicator) 35695-07D00 & 35695-07D10 NEW
Clutch pushrod seal 09285-06018 NEW
Clutch Pushrod 23111-15501 NEW
Fuel tap gasket 44305-17C00 NEW
Cooling sensor (in the thermostat) #34850-82011 NEW
Rocker cover Gasket 11173-30B02 New
Rocker cover bolt seal 09161-11008 (SET) NEW
Right engine cover access o-ring 09280-33004 NEW
Water pump emgine o-ring 17435-33400 NEW
coolant system bleed screw seal 09168-06026 NEW
Neutral switch o ring 09280-26003 NEW
Cush drive rubbers 64651-32C00 NEW
tank breather seal 09168-12012 NEW
USED PARTS:
Both yokes
Frame with V5
swingarm
rearsets
pillion hangers
both seats
SOLO SEAT COVER
SOME NEW PARTS:
Air filter OEM NEW
geeman88
Re: Braking 1992 GSXR 400 GK76A
how much for the air scoops and pipes???
gixxerpaul
hello only just seen yr post do you still have the tanks and what colour are they if you do thanks paul
1bostic87
- One Hit Wonder
Hi there, how much for the pillion hangers if you still got them? cheers
DrDomRob
- Bike owned: GPX750R, GSXR400, R1
Do you have the indicators, both front and rear, mirrors and clutch lever as well?
Dom
Dom
Austyn
Hi, I'm interested in the needles and emulsion tubes if you still have them?
Carter
any one had a reply from this guy? even emailed him with my shopping list lol
TeamGSXR
I've seen him post at random times to say he has parts but don't actually know if anyone managed to buy anything
GIXXER_PILOT
Got one tank in standard blue white coloursgixxerpaul wrote:hello only just seen yr post do you still have the tanks and what colour are they if you do thanks paul
I have a set of mirrors which i believe arent the orinal ones.
clutch lever is here
I have pillion pegs and hangers.
I am not often on here but will always be avaliable on 07795446655
Brett
Chain and sprockets?
