Best 98dB end cans?????
- skinnydog0_0
- Bike owned: Penny Farthing
Hi all, i am looking at getting a different end can to run in streetstocks. it needs to be 98dB!
I have a micron race can now and that is usually around 102dB,
I have seen a nice looking Scorpion oval/triangle carbon can that looks pretty good, anyone had one of these, or recomend a n other?
Re: Best 98dB end cans?????
Just stick a baffle in it matey.
Streetstocks with NG? Spike had a twin pipe system that was not quiet...
- skinnydog0_0
Hiya Bud, yes will be looking at doing a few with NG and i have seen DP do alot of races at Anglesey, so i might try to get a few in with them too, as Anglesey is quite close by.
I have got 2 baffles 1 short and 1 long, but i couldn't seem to get the bike running right with either one. I reckon i should get it on the dyno and see exactly what is happening.
I need to get it dyno'd in anycase so will try that first.
Are you doing any days with DP next year?
seems a stupid rule for tracks tbh,
i have a TYGA can, with yamamota rears and honda headers and it get 98dB with a cheap ebay baffle, but it loses midrange, and top speeds so i guess HP down loads,
i have a new baffle from gav at jap4 to test but bike is in bits at the min, so cant do a dB test just yet but looks like its been made very well as expected from tyga and jap4!
will update in the next month when powdercoatings done and bike back together!
- skinnydog0_0
Yes would be good to know what you are getting PD. I think i will try the baffle on the dyno and see what sort of difference it makes.
well when the prototype K&N gets sorted ill be upping the jets, 122.5 & 125's i think and ill see if a can book a few hours on a dyno, and sort jetting out and ill get full before and afters with tyga baffle and ebay baffle and see what happens i think gavin was expecting it back once id done a dB test, but i bet he wouldnt mind if i did dyno gains or loses with it. looking about 2months away for Dyno at least.skinnydog0_0 wrote:Yes would be good to know what you are getting PD. I think i will try the baffle on the dyno and see what sort of difference it makes.
but tbh if the sound is a loss on the tyga one is better over the ebay one ill buy it anyway for MOT time
i think they were £25 ish from gav, but im just his guinea pig to try it out for him. the ebay one was a reduce no doubt, but it makes a really anoying raspy sound that just pisses your off. but there was about a 10dB loss, which took it to 98db. ill see if i can find post and link it in here buddy.
will be back with results ASAP.
Rick
viewtopic.php?f=22&t=20676&p=142434&hil ... le#p142434
porndoguk wrote:whats the law?
reason i ask i had an advisory on my last mot, (exhaust to loud) and that was with a baffle on the much quieter FUEL can, since then ive gone for the shorter and louder TYGA can,
im doing a bike safe with the North Wales old bill in a fortnight, and thought id end up with a ticket, so bought a baffle on eBay, i thought id make my values into a fancy laminated A5 cert incase the old bill asks?
well tonight i bought home a Decibel meter from work.
the readings are as follows
Ambient Start dB = 45-49dB AV 47dB
Without (eBay) Baffle
Idle Slow - 1.5k RPM = 86-88dB AV 87dB
Idle Fast - 2k RPM = 95-97dB AV 96dB
Fast Race - 6k RPM = 102-106dB AV 104dB
With (eBay) Baffle
Idle Slow - 1.5k RPM = 80-83dB AV 81.5dB (-5.5dB)
Idle Fast - 2k RPM = 85-86dB AV 85.5dB (-10.5dB)
Fast Race - 6k RPM = 96-99dB AV 97.5dB (-6.5dB)
Ambient Finish dB = 45-49dB AV 47dB
i ran the bike on choke for several mins to get up to temp before using the idle screw to get a constant RPM and tested over 10secs to record HIGH/LOW Values.
- banoffee
Still very pleased with my Fuel can after a year or so. I run it with just the small end piece of the baffle, so not too loud but sounds great.
- skinnydog0_0
Cheers for that PD, useful info. I will get my tank off tomorrow and get you some pics of my air filter, i have a free flowing home made air filter on my rvf, it's a bit heath robinson, but it works and stops crap getting sucked into the carbs
- skinnydog0_0
Is that a stainless one banoffee, and how much was it?banoffee wrote:Still very pleased with my Fuel can after a year or so. I run it with just the small end piece of the baffle, so not too loud but sounds great.
