Help finding a part....
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham »
Hi Guys,
Part number 12:
http://www.cmsnl.com/honda-vfr400r3-199 ... _0400.html
Its the front brake master cylinder hose. David Silver states its un-available and now discountinued. Any ideas where I can get an aftermarket item of the same internal diameter?
Thank you.
Re: Help finding a part....
either get on ebay and find the seller doing the rear HRC hose with a free fornt one...or your local pirtek or otrher hydraulic supplier.
Pretty sure the ebay seller sell the green rear hose and a red/pink ;) front one.
alexwitham
Thank you mate.
banoffee
Post by banoffee »
non hygroscopic I believe it's called. got some in the garage if you want a piece
alexwitham
After a 10cm piece if you can sort me out Steve?
Thanks,
banoffee
Post by banoffee »
PM me your address
royster81
Post by royster81 »
alex, can you pop a picture up here when it's sorted as i'm interested to see it finished
CMSMJ1 wrote:either get on ebay and find the seller doing the rear HRC hose with a free fornt one...or your local pirtek or otrher hydraulic supplier.
I tried these and the front one sweats worse than the rear ones and discolours pretty quick too, mines in the bin now.
alexwitham
Will do Rhory. Currently I've bodged it with a bit of that HRC res hose, as DM says, its sweating like a mo-fo (strange that as it doesn't sweat on the rear). Steve is sorting me out a bit of non-hygroscopic hose so will get a pic of both so you can see.
Thanks,
alexwitham
