NC30 TT-F3 spec heads
See these on yahoo http://www.microsofttranslator.com/BV.a ... e105208817
Worth it? or are standard heads easily modified?
Re: NC30 TT-F3 spec heads
They've gone unsold on yahoo for months.
There's no way of telling what spec they are without seeing them in person.
From what I can make out on the intake port it looks like its been reduced for more velocity and not opened up as per HRC manual , but then again there is not much point in opening it up if you don't have the cams for longer lift and the +3mm rods for longer stay to charge the cylinder. That could very much be a home made HRC jobby for someone that didn't have the full race kit
but like Cam said you just wouldn't know until its in hand
