Fork woes
Posted: Sat Dec 04, 2010 9:48 pm
Hi guys,
So as some of you may know, lately ive been overhauling my nc30 as there is a list longer then my arm of things to do to it to even get it roadworthy.
Up until now its all been going well reasonably smoothly and its starting to look great. Anyway to cut to the chase;
Both fork seals were weaping badly (its been sat in a garage for about 5yrs) so I decided to take the forks off and change the seals and oil. As you know the damper bolt in the bottom of the forks have to be removed in order for the damper and stanchon to be removed, and this is where the trouble started.
The damper bolt was siezed in there good and proper, being as carefull as I could I still managed to round off the allen bolt, so then i tried an extractor tool, that stilll wouldnt budge it, the only thing left for me to do was to drill it out (as Ive seen mentioned on here).
having no previous experience in this I managed to damage the fork lower and damper seat beyond repair
Luckily the other fork's damper bolt wasnt so stubborn and I managed to loosen it without rounding the head too much.
So Im just after some advice as to what to do next? Im currently on the look out for a full set of second hand forks in good condition and have posted in the wanted section, but is there anywhere that I could get hold of a brand new set of lowers perhaps? and a damper seat?
hmm I knew things were going a bit too smoothly recently
