Headlight bulb question!!
spadey99
Post by spadey99 » Mon Nov 22, 2010 11:09 am
Hi there
I want brighter bulbs in the bike but heard that nc30s that are imported run lower wattage that cost a lot more, can you use normal h4 bulbs or will it burn the wiring loom?
Also when I rang for the insurance and said to the guy it was an import he said it isnt showing as an import so does it mean its a uk bike?
Any good place to get xenon effect bulbs for it?
Steve
banoffee
Re: Headlight bulb question!!
Post by banoffee » Mon Nov 22, 2010 1:55 pm
if it's a UK bike then you should have the 60/55 bulbs already
if not, you need to fit a low beam relay: http://www.vsource.org/VFR-RVF_files/NC ... mRelay.htm and snip the headlight lower lugs and use either a nail/pin or adapter rings (can get them from ebay).
does it have an oil cooler in the front fairing? got a pic of the bike?
Post by Neosophist » Mon Nov 22, 2010 10:32 pm
Once you get the low beam relay sorted (if needed) i'd recommend Phillips Extreeme bulbs... really good
thunderace
Bike owned: R6, YZF600R
Post by thunderace » Tue Nov 23, 2010 9:43 am
Neosophist wrote:i'd recommend Phillips Extreeme bulbs... really good
+1 for these beauties.
Also, where abouts are you? If you have any trouble fitting the relay I'd be only too glad to help if you're anywhere near Blackburn.
spadey99
Post by spadey99 » Tue Nov 23, 2010 7:08 pm
Hi mate
im in Cumbria dso only an hour from you so might call upon your help,
Steve
graham72
Bike owned: NC30,
Post by graham72 » Tue Nov 23, 2010 9:11 pm
:plus: Have to agree, immense improvement over standard bulbs!
thunderace
Post by thunderace » Tue Nov 23, 2010 9:27 pm
spadey99 wrote:Hi mate
Steve
No problems matey, just drop me a PM and i'll send you my number.
BTW, I have all the necessaries in stock :mrgreen:
