compression tester, which one.
Davez29
Bike owned: NC29 forever
Post by Davez29 »
With the NC29s disliking of anything stuffed down its spark plug holes, including spark plugs I was wondering what type of compression tester you men use, is it a soft hose type or rigid type on the bottom of the hose . Im going to do this and my valves next week so need to know before I buy one, thanks.
Wozza
Re: compression tester, which one.
Post by Wozza »
I have a Draper one - you also need to buy the adapter, but iirc that makes it long enough for easy fitment.
Davez29
Post by Davez29 »
So has your draper got the long metal tube or is it hose all the way down to the adapter, thats the bit im wondering about as I dont know if you can screw the hose one into the head easily.
Variablevalves suck
Post by Variablevalves suck »
http://www.amazon.co.uk/gp/product/B001 ... MZ4GGR7AXR
You may need a 10mm adapter but they are £4 from the same people.
Wozza
Post by Wozza »
Durka Durka wrote:So has your draper got the long metal tube or is it hose all the way down to the adapter, thats the bit im wondering about as I dont know if you can screw the hose one into the head easily.
It has the metal tube plus the adapter at the end of the hose.
