vfr nc30 indicaters not working
rob b
- Bike owned: nc30
Hello.
Could somebody please help me. I have just required a verry nice vfr 400 a lovely bike. But I have one problem none of the indicaters are working. I asked the guy who owned it & he said they are a bit funny when cold but are ok when bike has wormed up I tried that & still not working. Many thanks.
Rob.
Rob.
- leef82
- Bike owned: vfr400 nc30
Re: vfr nc30 indicaters not working
check the switch, it could be knackered or even the indicator relay and connections to indicators, things can get abit corroded or broken
lee
lee
- mattUKNC
Could you try another relay?
I probably have one in the garage you could try if need be?
Where abouts are you? There maybe someone closer who also has one.
rob b
- Bike owned: nc30
Thanks for that guy's. I'm on anglesey north wales. If you wanted to sell one I would buy one from you.
Many thanks.
Rob.
Many thanks.
Rob.
- mattUKNC
Sorry for delay Rob, PM you address and I'll get one posted.rob b wrote:Thanks for that guy's. I'm on anglesey north wales. If you wanted to sell one I would buy one from you.
Many thanks.
Rob.
rob b
- Bike owned: nc30
Any idea were the relay is on the bike & how to get at it. Thank you.
Rob.
Rob.
Pretty common problem with nc30's, the switchgear usually just needs a good clean.rob b wrote:I asked the guy who owned it & he said they are a bit funny when cold but are ok when bike has wormed up I tried that & still not working.
Take it apart, spray it with contact cleaner (or wd40) and remove all the grease build up.
- leef82
the relay is under the seat unit on the left side, next to the regulator/rectifier , its a little black unitrob b wrote:Thanks
Rob.
lee
rob b
- Bike owned: nc30
Hi.
A big thank you to you all for youre help.
I took the switch off today & sprayed a bit of contact cleaner into it & bobs yours uncle it's working like new just a five minute job. Thanks guy's. Cheers.
Rob.
Rob.
- mattUKNC
rob b wrote:Hi.
Rob.![]()
