what grease should i buy
marcus57
as above , what grease should i buy for greasing up linkages bearings ect ect, i have no idea
- skinnydog0_0
- Bike owned: Penny Farthing
Re: what grease should i buy
I use Castrol LM grease, it seems fine for pretty much everything apart from high temp stuff.
I know you can get specific grease for specific jobs, but the LM works fine for me
If in doubt consult the Bible (honda workshop manual)
http://akhara.com/nc30/nc30manuals/VFR4 ... 0R_C01.pdf
LM multipurpose grease is fine for a lot of things, good choice and fairly cheap.
However;
Some components should be lubricated with special greases to avoid undue damage.
Page 4 of that manual will show you all the greases used on the bike.. then if you flick to the part(s) your concerned about you can see what grease Mr Honda originally put there.
General rule of thumb.
Most parts: LM Grease
Bearings / shafts: Molybdenum (moly) grease
Camshafts: High moly grease (40%)
Silicon grease and moly/oil are used too so manuals worth a check
http://akhara.com/nc30/nc30manuals/VFR400R_Shop_Manual/
All the chapeters are there...
However;
marcus57
so for things like linkages and that it is fine?skinnydog0_0 wrote:I use Castrol LM grease, it seems fine for pretty much everything apart from high temp stuff.
mart when can i get some of that fancy grease off you, im in the process of doing the head bearings as you know. will that red bearing grease be ok for the head, as there not under high speed, heat or pressure. so on this occasion i think theyll be ok. what say you brother?
Have a look at the chapters of the Honda Service book I posted, it'll tell you exactly what grease to put where.marcus57 wrote:so for things like linkages and that it is fine?skinnydog0_0 wrote:I use Castrol LM grease, it seems fine for pretty much everything apart from high temp stuff.
I dont' see why it wouldn't be ok.. the shop manual saysrickyb_dj wrote:mart when can i get some of that fancy grease off you, im in the process of doing the head bearings as you know. will that red bearing grease be ok for the head, as there not under high speed, heat or pressure. so on this occasion i think theyll be ok. what say you brother?
Use multi Purpose Grease, (Lithium based multipurpose grease NLGI #2 or equivalent) though it isn't lithium based..
