RVF oe brake hose routing - help pic needed
- CRM
Well i can work out how the hell they go. does anyone have a pic of the standard way the front brake hose routes pls. these are the genuine rubber hoses and oddball link pipe
ta
ta
Re: RVF oe brake hose routing - help pic needed
You've got the fiche haven't you mate?
It comes down and bolts to the yok and has a gash splitter on there and then two lines down?
Sack them off and get some proper hoses...you know it makes sense!!
arsey30
- Bike owned: ftr223 650 bros
Pictures of hose route.
- CRM
brilliant superb, i wont tell you what i was doing wrong then - ok if you want a laugh, i was given a set of hoses and i couldnt work out where the rear brake hose went on the front - yes you read that right, the front hose assembly with the rear hose, and trying to work out how it ALL goes on the front
yep yep i know - coat - door....
thanks chaps
thanks chaps
