rvf carb service
code2006
rvf carb service
Post by code2006 »
hi guys i just changed my jets on my rvf and now i want to drill the slides useing a 2.5mm drill and put an extra washer 0.5mm on the needle but i can't figure it out how to take the needle off the slide
also i read somewere that its not recommended to drill the slides ?
also im following cammos diy guide and im not sure if i should adjust the pilot to two and a quarter turns out or 1 and 5/8th i think
my rvf is standard except i have a tyga carbon twin can full exhaust system
thanks alex
Re: rvf carb service
Well..
Don't do it. The drilling etc is for NC30 carbs only.
Stop fiddling dude... :o
code2006
Post by code2006 »
CMSMJ1 wrote:Well..
lol ok
how about the washer and pilot jet?
thanks
ibby4585
Bike owned: SP's
Post by ibby4585 »
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
Step away from the workbench!!
code2006
Post by code2006 »
ibby4585 wrote:
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
ok hmm what to do next lol
all i have left to do is my carbs and indicators lol
i think im gona make a cup of tea then start on my indicators till someone can correct me lol
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
Dyno it...see if it nees anything 8-)
code2006
Post by code2006 »
CMSMJ1 wrote:
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
yer will do that later on lol
for now i will leave the washer and set the pilot jet screw to 1 and 5/8 turns out
thanks
ps i know i dont need to change pilot jet it was the screw i was on about, just didnt know how many turns i had to do on the rvf carbs for std bike with tyga exhuast
:lol: For what its worth ive always found a extra 0.5mm washer and hrc slide springs work a treat on rvf carbs to sort out the midrange on engines with standard tune.
code2006
Post by code2006 »
Drunkn Munky wrote::lol: For what its worth ive always found a extra 0.5mm washer and hrc slide springs work a treat on rvf carbs to sort out the midrange on engines with standard tune.
well thats wot i thought but i couldnt figure out how to take the needle off the slider to put an extra washer
just re fitted the carbs and pannels and i forgot to turn the screw under the carbs that emptys the petrol out so i have to take the carbs off the bike again :x :x
will take the carbs off 2moro but it would be nice if there was some info about removing the needle
on the nc30 carbs theres a screw but i dont think there was a screw on mine :?
IIRC you remove the needle the same way as you do 30 carbs, philips screw driver inside the slide then twist. Im sure theres pics in the haynes manual. I always go up a jet size too if using a can or system. DONT drill the slides. 30 & 35 carbs are different beasts and using the 30 guide to mod your 35 carbs is going to end in tears.
