NC35 Starter Issue
thedonsRVF
NC35 Starter Issue
My bike started perfectly yesterday (like every day) but when I went to put it in garage after work I started it & thought it sounded sluggish so switched it off again, when I went to restart the best way I can describe it is when I pushed the start button the noise it made was 'trrrrrrr' like the starter wasn't engaging?
I put it away & when I went to start it later it turned over no problem.
What should I check to see if this will happen again?
Re: NC35 Starter Issue
Check the charging system firstly.
Sounds like it could have a dying battery.
