76a Neutral light always on
- monkers
- Bike owned: GSXR400R
My neutral light is always on. Been given a few steers as to where the problem might be, I have looked in front of the front sprocket. No trapped wires, looked for a diode on the n/s tail section of the wiring loom, couldn't see it. The light is slightly brighter when I put the bike in neutral but that is only because I am used to it. A few times I have come home after a ride and the light is off when I pull into the drive, then the light goes on as it should. Not sure if it has gone off at some point earlier and I haven't noticed, soon as I kill the ignition and switch it on again I'm back to it always being on. Did a search on the forum but could only find the reference to it being killed when the bike is de-restricted with a mod. Any ideas people?
							There are no secrets, you either know it or you don't.
						- thunderace
- Bike owned: R6, YZF600R
Re: 76a Neutral light always on
Sounds like a dodgy neutral switch on the gearbox. It may just be a bad connection or it may be the switch is fubar. It should be a screw-in thing on the box somewhere.
						- monkers
Anybody know 'where' exactly?thunderace wrote:Sounds like a dodgy neutral switch on the gearbox. It may just be a bad connection or it may be the switch is fubar. It should be a screw-in thing on the box somewhere.
						- monkers
OK, scrub that, know where it is now. Mechanics all seem fine with selector, must be the switch, have cleaned all the contacts. On another note, I had to take the clutch cover off. 3 of the 4 bearings are missing in the cable pull. Does anybody have or know what size they are? Or what I can rob them out of? Might as well hoover the bits and pieces up while I'm there.
