fairing fixings
BigDonk
fairing fixings
Post by BigDonk »
Hi folks
where is the best place to get hold of the fairing rubber o ring fixings that you push the panels in to hold them on and the fixings what I can assune are the dzus type fixings? My frame is devoid of 90% of them and has been fixed with volumes of electrical tape on the pins to pack then out :x
Trinirides
Bike owned: NC30 is all you need to know
Re: fairing fixings
Post by Trinirides »
Not sure what you mean by fairing rubber O ring fixings?? if you want a pack of fairing screws try http://www.tastynuts.com/Products/Honda ... _NC30_8994 these kits come with dzus fasteners and most other mounting screws.. If your bike is missing a fundamental fairing mount look here http://www.akhara.com/nc30/nc30parts/ copy the part number you want they order from http://www.davidsilverspares.co.uk/ simples... :peace:
thunderace
Bike owned: R6, YZF600R
Re: fairing fixings
Post by thunderace »
I think he means the rubber grommets that fit into the lugs on the frame?
BigDonk
Re: fairing fixings
Post by BigDonk »
thanx guys
aha grommets thats the word I was after.
checked this site out http://www.akhara.com/nc30/nc30parts/, but boy are the images difficult to read will persevere, but tastynuts seems a way forward
thunderace
Re: fairing fixings
Tastynuts are really over-priced for what they are. I can get stainless steel marine grade bolts for a fraction of the cost from a trade supplier.
Delboy
Re: fairing fixings
Post by Delboy »
Some good links there! 8-)
Trinirides
Re: fairing fixings
Atleast with tasty nuts its just a kit you order and away you go, no need to try and find part numbers and thread lenghs etc.. If you can get a full fairing set in Stainless steel for less than what the normal run of the mill fairing kit suppliers can then please post up part numbers and ordering information as im sure there will be quite a few takers..
BigDonk
Re: fairing fixings
Post by BigDonk »
I must agree with Thunderace that for Stainless Tasty nuts are a bit on the steep side as in rope your selves together it that steep, but the anodised are not to bad, as a local stainless stockists up my way are a bit scarce
but triniriderz does make a good point though
thunderace
Re: fairing fixings
Let me know what sizes and quantities for the different bikes and I'll try and put a package together.
I buy bolts in packs of 50 or 100 depending on size (works out way cheaper than buying 5 or 10) so I always have a decent stock of popular sizes in M5 and M6 threads.
