GK76a Not Starting, Possible Fuel Problem
				DeeJ
- Bike owned: GSXR400 GK76a
I bought a 1990 gsxr gk76a yesterday, it was starting up fine apart from a knackered battery which needs charging all the time.
I put some fresh fuel in it last night and then left it to rest overnight, I had turned the fuel tap to OFF overnight.
I came to start it up this morning after putting the fuel tap to ON, and nothing, it wouldn't start.
Only thing I can think of is that the fuel tap has stuck on OFF.
Can anyone enlighten me here.
DeeJ
DeeJ
				Kev_gk73
Re: GK76a Not Starting, Possible Fuel Problem
dont know if its the same as my GK73 but if it has a "PRI" (prime) setting, try it on that and make sure your lines are all connected including vacuum.
drain the bottom of the carbs and let the fresh fuel come through the system, mines took a little time to pull it through but eventually burst into life, use a little choke aswell.
I am only speaking from experience with mine and your bike may be different but try it anyway, if not then someone else should be able to help you out.
- Variablevalves suck
Yep as kev say's. Also if not good take a look if you got a spark and the flat battery may point to a knackered regulator or bad wire connection.
				DeeJ
Hi, i am a total noob and thought the PRI somehow was OFF.
I've tried to start it with the tap on prime but still not going.
How do I drain the fuel through the carbs
				Tony19580
- Bike owned: GK76a
On the bottom of each carb is a screw, undo these a couple of turns then do back up, put pump back to on and give that a go.
				DeeJ
I will have ago tomorrow then, thanksTony19580 wrote:On the bottom of each carb is a screw, undo these a couple of turns then do back up, put pump back to on and give that a go.
				DeeJ
Spark plugs were totally soaked so changed them today and gave it an oil change
Started up straight away
