NC29 carbs flood
marccw
- Bike owned: nc29
NC29 carbs flood
New bee in need of some help,
Ive just brought an nc29 which has been stood up for about 5 years, connected a new battery to start her, after a couple of minuits she slowly burbles into life, in my excitment of her starting i did'nt notice the petrol flowing over the engine and soaking my feet, dose anyone have any ideas as to what the problem is.
- Davez29
- Bike owned: NC29 forever
Re: NC29 carbs flood
They are more than likely gummed up or stuck open around the float area. Take your carbs off, clean them internally and check float heights and that they move on the pins, finally check that the float valves are working and sealing correctly. Hopefully this will help and get the bike working.
cajun
- Bike owned: MC22, NC29,NC35, 2 FZR400's
If it's not the floats it could be the "O" rings between each individual carb.
- chrisja2
- Bike owned: nc29 trackbike
Mine spewed petrol out of the carbs when i first started it, had been stood for a couple of years too. Stripped the carbs and found the floats had stuck as the pertol had turned gummy. Strip your carbs out and give em a good service, the bike will thank you for it.
marccw
- Bike owned: nc29
Cheers people took off the carbs floats 2 and 3 were sticky and the needles had a nice layer of yellow goo on them, have not got an air line so used loads of carb cleaner and lots of blowing (hope that is enoughas i can now see through the jets) hoping to put them back on tomorrow.
marccw
- Bike owned: nc29
Got the carbs on and fired her up cleaning them out did the trick, she runs but roughly as soon as i try to let it idle it stalls, would balancing them sort this ?
cajun
More than likely you didn't clean every jet. Meaning EVERY single screw and jet that can come out. That plus balancing the carbs would help.
