Fuel pump and / or fuel related issues?
greywolfhunter
- Bike owned: GSX-R 400 GK73A
- Location: Bridge of weir (About 15 miles West of Glasgow)
I went for a cheeky blast on my gk73a today, just from one town to the next and hammered it for all it was worth, and then as i was coming back, the engine started to splutter and eventually cut out (about 50 meters from the town entrance) and i noticed when i tilted it to the left side it started, i know the fuel tap is on that side, but is there a fuel pump in the 400 models? i've been googling for about 10 mins and found little to nothing of gsxr fuel pumps...
anyone else has this / these problems?
silbeer
- Bike owned: GK76A
Re: Fuel pump and / or fuel related issues?
No fuel pump, just gravity feed. Perhapse broken straw off the tap?
Benr
- Bike owned: Suzuki GSXR400RRsp GK73
Have you tried turning it to the reserve position?
greywolfhunter
yea, it was on normal then reserve, i thought it could have been an issue but its not, seems to be feeding through okay, perhaps some other blockage?
silbeer
- Bike owned: GK76A
If the straw in the filter breaks then there would not be any fuel left for the reserve. Pull the fuel tap out of the tank and check it's not cracked or broken
morris147
Does it have the "Pri" setting on yours?
If so, try that.
EDIT: sounds like you run out of fuel.
If so, try that.
greywolfhunter
actually, yea.. i think you guys are right, probably just ran out of fuel
