tank bracket
TROUBLED OTTER
Bike owned: DUCATI STREETFIGHTER,NC35,250R
tank bracket
Post by TROUBLED OTTER »
Hi Guys,Anyone know if there is a bracket that the front of the tank fits into.I think mines missing. Image Image
Re: tank bracket
there is a rubber foot kind of jobbie that fits in the tank and rests on the frame...
Re: tank bracket
Nothing missing, the rubber moulding should slot into the cutout on the frame
TROUBLED OTTER
Re: tank bracket
Doent seem to hold it nice and tight.At the rear of the tank there is a plastic wedge and thats it.I do have two little rubbers which seem to fit on the bottom outside lip of the tank too but dont know were.Trying to line this body to the tank. Image
hunter
Re: tank bracket
Post by hunter »
Re: tank bracket
The 2 rubber bumpstops you have are probably the ones that sit on the underside of the tank on each outer edge and should sit on the frame spars. If they dont touch get some 3mm think foam tape and run a strip along each frame spar, that usually stops the rocking. You should have a rubber cushion at the rear fixing not plastic.
TROUBLED OTTER
Re: tank bracket
Thanks for the help guys.I,ll have a play around with it tonight.
