Derestrictor
Sam
Derestrictor
Post by Sam »
I was looking through a box of bits and found this little device. I believe its a desrestrictor, is that true?
Where does it plug into? Is somewhere near the CDI?
Also where are the nc30's restricted i.e is it in the rev range or top speed?
Thanks.
banoffee
Re: Derestrictor
Post by banoffee »
going by that pic it looks like it plugs into the loom where you'd normally plug in the speedo. so, nose cone off then easy job.
top speed.
viper_biker
Re: Derestrictor
Post by viper_biker »
Is it not an indicator relay?
Dgeoff33
Bike owned: RVF400 - ZX636
Re: Derestrictor
Post by Dgeoff33 »
I was under the impression that it replaces the speedo on track bikes as I have a few on some old looms, may be wrong though.
superlite
Bike owned: TLS, LB80 x 2
Re: Derestrictor
Post by superlite »
A desristrictor would usually plug in-line - so it would have two plugs. I've never seen a deristrictor with only one plug and three wires - could well be a really ugly indicator relay with that plug. And certainly won't plug into the CDI or speedo loom. Won't fit an NC35 either.
For comparison, my NC30 deristrictor (Posh) has two plugs with 5 wires each.
'Take it to the Back'
Re: Derestrictor
The one on my ZXR connects from where the speedo clocks join the wiring loom, rather than down at the CDI end like the HRC (and clone) boxes fit.
So it could be, I can't remember what that connector looks like that comes out of the back of the clocks on the VFR's, pretty sure it has 3 wires though..
Dgeoff33
Re: Derestrictor
Post by Dgeoff33 »
I can guarantee it plugs into the speedo loom when the speedo has been removed, I have at least 3 that have been done.
If I knew how to post pics I would put some up to show you.
Re: Derestrictor
Like that ^^
Sam
Re: Derestrictor
Post by Sam »
Well i fitted it to the bike at the speedo, definately fits but dont know what it does as im still sorting out the bike so wont know for a while.
What will it actually do on a road bike? Anything or best of binning it?
Cammo
Re: Derestrictor
Post by Cammo »
It will probably remove the standard Jap model 180km/h speed restriction, giving you a higher top speed. All Jap models are restricted to 180km/h as standard.
Being a non inline unit it will also allow you to unplug/remove your speedo (on a track bike) while still removing the speed restriction.
