Throttle grip, clip on and bar weight random question
400baby
I've just bought yet another eBay bargain ( after buying an nc29 for my wife), I've now bought one for myself. Can any one tell me if the throttle grip is proud of the end of the bar as mine is, and does the bar weight fill this short coming to the end of the grip. Appreciate any tech help.
- Davez29
- Bike owned: NC29 forever
Re: Throttle grip, clip on and bar weight random question
My throttle grip is over the end of the clip on, the inner weight is flush with the end of the clip on and the weight although tight up is still out by about the length of the cut out on the weight, if that makes sense? The clutch side end weight is flush with the end of the grip and no gap as you would expect.
justmartyn
If you've an aftermarket set of grips on, then by the sounds of things you have a long pair on. The NC29 uses a slightly shorter one as the throttle tube isnt as long.
400baby
I don't know if they are aftermarket grips, (they could be anything, after all most 400's are owned by at some point by a kid in there late teens with the mechanical sympathy of a house brick!) I've just bought a replacement clip on and throttle grip and they are the same as the one I've taken off. From the inside out you've got, the clip on, then there's the throttle twist tube (the bit the cables go into), this over hangs the end of the clip on by a bit under 10mm. Then the grip over the top is only a few millimetres over the end of the twist grip. Then the bar end weight slots into the end, although looking on eBay, it looks as tho there could be an inner part that goes into the clip on, my end weights are only a 2" long at most. I've only started to play with this as one of the previous owners had replaced the grip but had cut it down to fit the throttle tube, and left the bar weight lose!
cbr400rrn
- Bike owned: NC29 CBR600F
There is an inner bar end weight that the outer bar end weight screws into.
My throttle grip has been trimmed back slightly by a previous owner and it is something i have never thought about changing as it does the job and you cannot tell it has been trimmed back really unless you know what you are looking for or had the throttle in bits
400baby
Ah that sounds like the problem then, no inner bar weight, as the clip on is hollow, and the current bar weight is just on an expanding rubber bung. Cheers guys
cbr400rrn
http://www.cmsnl.com/
Try this website and search for your model, look through the microfiches and you will be able to see the part you need
Wozza
Graeme France can supply these inner bar weights.
400baby
Cheers wozza, 2 emails and a bit of cash later and GF sent me a complete set of weights no hassle. One problem down, umpteen more to go!!!
