nc30 front and rear suspension options
marcus57
hi guys both the front and rear shocks on my nc are as soft as s##t.
what options do i have ? obviously i could just get them serviced re sprung and valved.
what i would like to know is there any better/more cost affective alterative options?
marcus57
- Jon
Re: nc30 front and rear suspension options
To save a bit on the front you can buy springs and valve upgrade ect from someone like Rick Oliver and do the work yourself.
Rear you may be lucky and pick up a good 2nd hand aftermarket rear shock but I wouldn't hold your breath.
Suspension and tyres make or break an NC30 IMHO so bite the bullet and do it right.
cheers
jon
cheers
jon
marcus57
i want to do it rite, its just that iv been reading on here about people having there shocks lengethend 10-13mm? whats the gain in doing this?
also i have seen people saying about using rs250 rear shock? again whats the advantage?
theoutsider
I think people tend to go for the rs250 shocks because they are easy to mod,and have height adjuster.marcus57 wrote:i want to do it rite, its just that iv been reading on here about people having there shocks lengethend 10-13mm? whats the gain in doing this?
I think you need to put your nc30 spring on the rs250 shock.
- superlite
- Bike owned: TLS, LB80 x 2
You generally don't lengthen the standard '30 shock (you can, but it comes with a hefty price), you can mod the dogbone linkage that it mounts to by drilling new holes and filling the old ones (basically shortening the linkage). The ratio is 3.5:1, so 10 mm shorter will give you ride height lift of 35 mm. Certainly no substitute for an aftermarket shock, but quickens up the handling very nicely and does the job if your're on a budget (and if the bike has more skills than you!)marcus57 wrote:i want to do it rite, its just that iv been reading on here about people having there shocks lengethend 10-13mm? whats the gain in doing this?
'Take it to the Back'
Check out this thread mate, not as good as a decent aftermarket shock, but a big improvement in handling for very little cost:marcus57 wrote:i want to do it rite, its just that iv been reading on here about people having there shocks lengethend 10-13mm? whats the gain in doing this?
viewtopic.php?f=24&t=5346&p=37396&hilit=dogbone#p37396
marcus57
just to clarify then? if i fit a rs250 rear shock i have to fit my nc30 spring to it? do i have to do the rear linkage mod? what the gain in the rs rear shock over the nc item?
- superlite
You have to change the spring on the RS250 shock, you can get away with the stock NC30 spring, but aftermarket matched to your weight would be better again.marcus57 wrote:just to clarify then? if i fit a rs250 rear shock i have to fit my nc30 spring to it? do i have to do the rear linkage mod? what the gain in the rs rear shock over the nc item?
You definitely don't do the linkage mod with the RS250 shock: the shock is already longer than the standard NC30 unit and also has adjustable ride height. The main advantage of the RS250 shock is that it's longer, more adjustable (if you get the right model) and newer, so you know it'll be a bit fresher than a 20 year-old NC30 shock.
Here's some details on the RS250 shock mod (RVF website, but fitting is for NC30):
http://www.hondarvf.com/workshop/modifi ... dification
