Nothing off the button
Hadies
Post by Hadies »
Hi again,
I've spent far too much time in this section of the forum :grin:
I've recently changed the oil, fitted tyga system and upjetted the carbs on my NC30. Now I've put it all back together (I think) and I go to press the button and nothing. I've rechecked all the connections and I can't work it out! Please enlighten me 400greybikers.
What I have noticed is that my neutral light now doesnt work now.
Its doing my head in! Suggestions from everyone please!
Re: Nothing off the button
Check your fuses... ;)
Hadies
Post by Hadies »
Checked the fuse box under the seat and the one by the coolant reservoir and they're ok.
I also forgot to add that I have taken off the rearsets - just incase theres something around there I've knocked.
have you checked the main fuse?
Do you have a hydraulic brake switch? I popped my fuse by touching the frame with the contacts on my switch...
Hadies
Post by Hadies »
The main fuse is ok. I havent fitted my new rearsets yet as im waiting for a banjo pressure switch. I've only removed the standard rear sets and the wiring for the rear brake light
Any power with the ignition on?
IE headlights / oil pressure idiot light?
Hadies
Post by Hadies »
Oil light stays on, lights, indicators etc work. My neutral light wont come on though and it used to work.
Hadies
Post by Hadies »
Good news all. I pulled out the neutral light switch, gave it a clean, popped it back in. Full choke, no throttle and away I went.
Thanks for the advice everyone :grin: :grin: :grin:
:rocks:
Hadies wrote:Good news all. I pulled out the neutral light switch, gave it a clean, popped it back in. Full choke, no throttle and away I went.
:rocks:
Yep it wont crank if the neutral light isn't on :)
Well it might if you pull the clutch in... :D
