FZR 1WG Carbs
IanG1
FZR 1WG Carbs
Post by IanG1 »
Anyone know what numbers are marked on these carbs and are the pre exup the same as the exup (3EN1) setup?
Ta
Ian
how69
Re: FZR 1WG Carbs
Post by how69 »
Just looking at the iwg and 3en1 manuals and part books.
they are not the same carb, different part numbers and not put together just the same.
weather a 1wg carb works on a 3en1 I cant tell you.
IanG1
Re: FZR 1WG Carbs
Post by IanG1 »
Any idea on the id numbers stamped on, I have a pre exup 1wg but wanted to know amongst other things if I could run later carbs
Marb
Thieving Pikey Twat
Thieving Pikey Twat
Re: FZR 1WG Carbs
Post by Marb »
If i remember correctly you can run later carbs on an 1WG (such as the faltslides from a RRSP) but you can't run the 1WG carbs on an later bike. The carbs wil need to be set right for your bike, so a dyno run is advisable. Atm i am running a set of '91 FZR600 carbs on my 3EN2. They were re-jetted and setup on a dyno but they run really well
