Tyga Suzuka Style Upper with Alloy Meter Stay Fitment Issue
summitdog
Has anyone had an issue with the fitment of the Tyga alloy meter stay to the Suzuka style upper? There are no directions and the placement/attaching of the headlight is perplexing me. Any assistance will be appreciated.
Thanks,
Scotty
Thanks,
Scotty
- Riley
Re: Tyga Suzuka Style Upper with Alloy Meter Stay Fitment Issue
I have the Tyga suzuka front fairing/tyga meter stay combo on my bike, to be honest I've found it very straight forward. The light weight meter stay is a direct replacement for the origonal (infact the standard item can be used), there should be a black extension piece supplied with the fairing which attaches to the front of the meter stay. The spotlight should be fitted on the lhs of the fairing (as sat) by 2 bolts/nuts. The single head light should be fitted to the light weight meter stay/light stay as per the standard light stay. Other than than that it just fits as normal aside from the rhs light connector should be fitted to the new spot light. Hope this helps/makes sense.
summitdog
It makes sense but I think I am going to have to post some photos of my situation to see if you can clarify a bit more.
Thanks,
Scotty
Thanks,
Scotty
