Some polishing +advice
0G0R3K-15
- Bike owned: Yamaha FZR 400 Genesis 1986
Hi. I began polishing my bike. Well some parts of it to make it look better without side fairings.
This is the effect of spending 5 quid and 3 days of hard work. But there are still bits that need to be finished such as those painted parts next to fitting brackets. there are also these things left after welding and dont know what should i do with them so that i'll be able to clean it perfectly. Can i just use an angle grinder? Am using only sandpaper and water to rip the paint off and my hands to polish with a piece of cloth and Autosol polishing paste.
What do u think of the effect as for the first timer? This will be polished once again with Autosol M1
MrTadSlow
- Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
Re: Some polishing +advice
~~~TOP BANANA DUDE~~~
0G0R3K-15
If you've got a drill you can get a polishing kit for £20 of Das 'Bay.
Autosol is ok but it doesn't last as long as proper metal polish, your hands will be relieved too
Good job so far though, nice work.
0G0R3K-15
But do u know what bout these weldings? Can I flatten them using an angle grinder? Only at the sides of it, not next to the brackets so that they don't fall off
MrTadSlow
I'm no expert but i think the welds must say...... I've never seen them
ground flush, put like i say I'm not an expert !!
As for the compound I've seen being used with a polishing mop, it looks
like a long snooker cue chalk !!
keep on going your doing a good Job
Stu.
Stu.
hunter
if you remove the welds you will weaken the frame.
0G0R3K-15
so what to do to make them shine?
Try a soft wire brush to take the paint anodising off then just buff them up. Good welding is nice to see once you understand how it's done
- Kayla850
- Bike owned: Sunn Tzar S2
The bits you're polishing are steel, you know? They'll rust if you leave them unprotected.
www.projection-racing.com
www.pjcfasteners.com
