fuel tap
fuel tap
Hi,
really stupid question and i am sorry but this is my first nc 30 and it has a tyga kit on and cant see the fuel tap, is the straight up position on, half way off and straight down the reserve.
Reedy,
Also can the ride height be adjusted with a standard shock?, also what oil do you guys recomened
Reedy,
- royster81
Re: fuel tap
if your standing beside the bike looking at the tap ,whatever is on top (at 12 o'clock) is what it's at, if i remember right if ON is at 12 and you turn it right one click thats OFF and one more click right is RES
Re: fuel tap
Thanks for you help mate,any advice on my question regarding ride height and oil.
- superlite
- Bike owned: TLS, LB80 x 2
Re: fuel tap
The standard shocks do not have ride height adjustment I'm afraid
They do have pre-load and damping though.
There are some cheap (and not so cheap) options to gain some extra ride height.
10w 40 is the recommended oil, but to be honest the little V4s aren't too fussy as long as you change it regularly. Semi-synthetic works well for me. In my experience, full synthetic can give a little clutch slip.
'Take it to the Back'
Re: fuel tap
Thanks very much for tour help.
- banoffee
Re: fuel tap
ride height - are you wanting to raise or lower it?
Re: fuel tap
Hi There i am looking to increase the height please.
Reedy.
Reedy.
- royster81
Re: fuel tap
mod yourrear link then ,rick oliver does (or did) a conversion were you sent him your rear linkage and he modded it and returned it, i jacked the rear up 27mm or similar and increased leg room and turn in, a worthwhile mod if you ask me
Re: fuel tap
thanks very much will try that
Re: fuel tap
Eh? Your footpegs and seat would still be in the same place, relative to each other.royster81 wrote:mod yourrear link then ,rick oliver does (or did) a conversion were you sent him your rear linkage and he modded it and returned it, i jacked the rear up 27mm or similar and increased leg room and turn in, a worthwhile mod if you ask me
