URGENT! HELP NEEDED ASAP.
- ChowderV4
im in the process of putting an r6 reg rec on my nc30 i've got all the spades and wires sorted and i,ve put them in as if you were looking into the plug, Red (Top left) / Green (Top Right) then 3 yellows at the bottom.
but my bike has absolutely no power, i turn ignition on and there is no neutral light no oil light nothing?!
whats happened, i need my bike to get to work 2moro
Re: URGENT! HELP NEEDED ASAP.
Sure you havent disconnected something else, you should still get power even with the reg disconnected. Check ya fuses?
- skinnydog0_0
- Bike owned: Penny Farthing
Drunkn Munky wrote:Sure you havent disconnected something else, you should still get power even with the reg disconnected. Check ya fuses?
Did you disconect the battery, CDI, any of the clocks? is the bike in gear?
Do you have a voltage on the battery?
- ChowderV4
cheers guys problem sorted, the starter motor fuse had blown.
runnning lovely now
runnning lovely now
- ChowderV4
ok think i spoke too soon.... just left it on tick over with full beam on to see if the battery dies, came back 5 mins later turned it off went to turn it on and it struggled to turn over, any ideas why the battery is still loosing charge
- skinnydog0_0
Can you test the battery voltage?
What is the voltage with the ignition off, and the voltage while starting?
Possible earth on the new connections to the regulator?
- Bike owned: NC35
Did you replace the reg/rec as an upgrade or because you blew the old one? if you blew the old one the battery could be well past its best
- ChowderV4
The battery could be fooked, but It was a new battery recently.
Basically the original reg rec was
finished when I took that off I got the new
battery and put an upgraded Honda reg on.
But I think it was the connector that had packed in as it was pretty much
melted.
It still lost charge with the upgraded reg on so I've done the r6 mod and after riding home in the dark with low beam on all the way home, the bike died when I stopped at home.
I turned the ignition off and on and the battery was dead so I've put it on charge.
I just don't understand why the r6 mod hasn't sorted it.
melted.
- Bike owned: NC35
this sounds very similar to my problems, I had one battery die of unknown causes, where it left me stranded after i stopped and wouldnt turn back on, a new battery and 2 months later the same happens, hard riding and hot both days. Checking generator all have perfectly within spec resistances but only 42V ac at 5000rpm(i should have used this information i think...). ANOTHER new battery and an old mc18? reg/rec fitted and within 70 km pop battery dead, scorched marks on the plugs.ChowderV4 wrote:The battery could be fooked, but It was a new battery recently.
melted.
So now... i have r6 mod done, and a new elextrex world gerenator waiting to go in.
will put it in this w.e however im still waiting on new rocker cover gaskets after doing valve clearances so depending on when these arrive ill let you know how it goes.
If you have replaced the battery and r/r theres only wiring and gennie left... 60 pounds for gennie to so not too bad...
