Carb problem
DanR
Carb problem
Hello all,
I did the carb upgrade/settings as above including drilling the slides, but on the test ride I noticed the flat spot was worse than before, but the rest of the ride was sweet.
I checked i had'nt pinched diaphrams etc but i'm bit worried now that ive drilled out slides it wont ride nicely.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
- Deviant400
Re: Carb problem
did you add the extra washer under the needles ? remove them if you have see how it goes
viewtopic.php?f=62&t=27307
Re: Carb problem
Deviant400 wrote:did you add the extra washer under the needles ? remove them if you have see how it goes
As has been said a lot on here..don't do stuff if you don't know why you are doing it! If you knew what the washer did and then you felt the change you would know to put it back..
just my tuppence..
Also helps to do one thing at a time.so if something is knackered you know how to get your bike back to a working status
DanR
Re: Carb problem
Yes i added the extra washers.
I did this to improve the flat spot.
