For those who want to do USD conversion on NC30
If you would like to change your forks to USD from zxr 400 L,do not swap the stem.Tried today,took the stem out of the nc30 bottom yoke,took out the one from the zxr 400,and I`ve put the nc30 stem into the zxr bottom yoke.IT WONT FIT,the nc30 stem is too small,not by much(half a mm)
So my advice,do not believe in the stories that you just take the stem out of the nc30,and put it on zxr.What is even the point of putting the ZXR Yoke in the oven and the stem in the freezer>?The yoke will come back to it`s initial size,haven`t tried it but is pointless.
Good Luck.
Good Luck.
Re: For those who want to do USD conversion on NC30
i have done a couple,you have to machine a sleeve and weld it on to the bottom of the nc30 stem,i usually drill the yoke and stem and put a 6mm bolt through to pin it,the top yoke also needs boring out to fit.
The same applies tin fitting them to the FZR4003TJ.
I just had a quote to fit a sleeve 120 quid.And the the stem from the zxr is smashed to bits.
Now I need bottom yoke,and RO conversion kit
Just buy the conversion kit,you wont save any money .It`s getting rather expensive
I've a new conversion kit here that does VFR to RVF for sale if anyone's interested. It includes the bearing and everything. I'm not sure if it's the same as a ZXR kit though.
you also need to make new lockstops,i recently sold a set i converted for less than that.
Yep.. you can get a good ZXR-400 for quite cheap these daystheoutsider wrote:IJust buy the conversion kit,you wont save any money .It`s getting rather expensive
Problem sorted
Wanted yokes and conversion kit,if you have one floating about let me know.
Neo don`t tell me you are donating to me your zxr.
- Smev
- Bike owned: NC30 of course
Mate as I said in the PMs you sent me - it was over 6 years ago that I did mine and got a mates Dad to do the machining for me as He has all the precision equipment available to him.theoutsider wrote:What is even the point of putting the ZXR Yoke in the oven and the stem in the freezer>?The yoke will come back to it`s initial size- Exactly the Point
Good Luck.
Heating one part will expand it and cooling the other will make it contract - even if it is just fractions of a mm. This allowed me to fit the new Machined NC30 stem to the ZXR yoke. Once they both returned to their original temperature, they are locked together pretty solidly - its basic engineering.
Its takes time and alot of work to sort these kinds of mods out - its not just the kinda thing you decide to do, and complete on a saturday afternoon.
Mister Donut Rep NC30
- Bike owned: VFR400 NC30 91'x2 Zxr750L2'x1
My Nc stem pressed into my zxr lower yoke okay
