Page 1 of 3
Most fun/£
Posted: Mon May 03, 2010 10:38 pm
by joshmolloy
My NC30 is currently totally standard apart from braided lines, an ART can, and some of the material on the airbox "scoop" removed.
What mods do you guys recommend that offer the best value for money?
Re: Most fun/£
Posted: Mon May 03, 2010 11:06 pm
by Drunkn Munky
Its been said a million times but suspension is gunna give you most smiles per £.
Do the carb mods if you havent already, drill slides etc. Theres plenty of threads on it
Re: Most fun/£
Posted: Mon May 03, 2010 11:08 pm
by joshmolloy
Is there much that can be done suspension-wise on a budget? Or am I looking at shelling out for a new shock at the least?
Re: Most fun/£
Posted: Mon May 03, 2010 11:17 pm
by Drunkn Munky
Later type remote res shocks can be rebuilt, K Tech charge £80 ish i think, Front end can be rebuilt for £100 with stiffer springs. You could get a stiffer spring for the rear too for around £30.
Re: Most fun/£
Posted: Tue May 04, 2010 7:19 am
by mick.mh2racing
Sort your gearing out for less than £100 with new chain and sprockets. Lose a tooth on the front and go up on the rear by 2 or 3. You'll lose top end speed but gain acceleration.
Re: Most fun/£
Posted: Tue May 04, 2010 10:26 am
by joshmolloy
mick.mh2racing wrote:Sort your gearing out for less than £100 with new chain and sprockets. Lose a tooth on the front and go up on the rear by 2 or 3. You'll lose top end speed but gain acceleration.
I have actually just moved back to the standard gearing from a -1 on the front setup, and quite like it.
Re: Most fun/£
Posted: Tue May 04, 2010 10:36 am
by joshmolloy
Drunkn Munky wrote:Later type remote res shocks can be rebuilt, K Tech charge £80 ish i think, Front end can be rebuilt for £100 with stiffer springs. You could get a stiffer spring for the rear too for around £30.
So you think I could get it nicely sorted for £210? Does that include it being setup to my weight, riding style etc?
Sounds like genuine value for money actually.
Re: Most fun/£
Posted: Tue May 04, 2010 1:45 pm
by mattUKNC
If you don't mind getting your hand dirty, I'd say do the forks yourself, I really enjoyed doing the ones on my 30.
RickOliver on here does a kit which includes (well it did when I did mine) a syringe so you don't overfill the oil! A great little kit. Around £85 too!
Re: Most fun/£
Posted: Tue May 04, 2010 1:59 pm
by joshmolloy
mattUKSP1 wrote:If you don't mind getting your hand dirty, I'd say do the forks yourself, I really enjoyed doing the ones on my 30.
As good as a pro setup? Does it come with different spring weights/oil weights to suit?
Re: Most fun/£
Posted: Tue May 04, 2010 2:10 pm
by Drunkn Munky
No just 1 weight of spring and oil, im sure rick will advise you if it was right for your weight but im 11 stone and fitted one to a NC35 and its was spot on, if anything a little on the hard side but thats how i like it.
