How to check ECU/CDI?
PARUS
Post by PARUS »
I have connected battery up-side-down and burned man fuse couple of times. I suggest that ECU (Ignition Control Unit) could be burned, but not sure because fuel cut-off relay (that gets signals from same wires from ECU) turn-on fuel pump. So, I'm not sure - what is really wrong. But I like to check ECU condition as well.
Are there any possiblity to check ECU\CDI operability ? Thanks for any help.
Variablevalves suck
Re: How to check ECU/CDI?
Post by Variablevalves suck »
I dont know how to test the cbr ecu but you can test them. You need to know what resistances you get between each connection. Some manufacturers put the info in the manuals so you will have to have a good google or compare to a known good one.
PARUS
Post by PARUS »
Variablevalves suck wrote:I dont know how to test the cbr ecu but you can test them. You need to know what resistances you get between each connection. Some manufacturers put the info in the manuals so you will have to have a good google or compare to a known good one.
The manual does not cotains any info about checking CDI - thay only recommend to send it to dealer. Unfortunatelly our Honda dealer wouldn't like to deal with old bike and I think ever cheaper for me to buy spare ones. :cry:
kevin wilson
Post by kevin wilson »
check and see do u still have spark at the plugs is all i can suggest ,,if the plugs are still sparking that means the cdi is good,,
garyboy_palaboy
Post by garyboy_palaboy »
if you knew someone who have a Super4, you can try its CDI. the connectors are the same with NC29 and the engine would run.
if that wont work, probably you have a busted CDI or a shorted harness.
PARUS
Post by PARUS »
kevin wilson wrote:check and see do u still have spark at the plugs is all i can suggest ,,if the plugs are still sparking that means the cdi is good,,
The problem is that there is no spark at all 4 spark plugs.
PARUS
Post by PARUS »
garyboy_palaboy wrote:if you knew someone who have a Super4, you can try its CDI. the connectors are the same with NC29 and the engine would run.
Thank you mate. CB400SF more easy to find here than NC29.
garyboy_palaboy
Make sure you dont have a shorted harness or electrical when you try the cdi of the super four, or else you end up damaging the cdi!!! then you will have two CDI to think about!
I would suggest, try first your cdi to the super four.
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr »
maybe you can check the CDI wiring continuity first ?
the picture below will give U some idea.
for the rest, please click the link below.
http://img222.imageshack.us/gal.php?g=dsc01745aw.jpg
actually, its not easy for the CDI to malfunction. I have a CDI which the sealer gum inside has been badly melted due to the battery over-charging, but its still functioning very well.
the picture of the melted sealer gum inside the CDI.
Variablevalves suck
Start by checking if you got 12v at the coils which is usually switched by a relay- so check this also.
