Little bit of help with dead NC30 please
dannyw35
Hi,
We have this NC30 which recently stalled just as we were pulling onto the drive - didn't think too much as initially we thought we just let the clutch out too fast.
Upon checking the bike, it turns out that there was no power - as in no dash lights/no electrics at all.
Asked on another forum and they mentioned it could be the fuses so I checked the ones under the rear seat, found one had blown so change it - still nothing. Changed the 'ignition' fuse too although it looked fine and bingo, the dash lights were on...
Only thing is that the lights were very dim and often went off after a few secs...
I then got a charger and hooked it up to the bike...the battery was reading 12.?v (so I am guessing it isn't that).
Decided to try the ignition again...sometimes the dash lights would dim out (when I turn the ignition on the battery volt goes to near 0) but on other occasions it would be bright and stay that way (the battery volt doesn't fall as low in this scenario)
When the lights are bright, I tried starting the bike...it certainly doesn't fire up...instead I hear this weird shrieking noise from this thing (I don't know what this is so someone can enlighten me
) which is located in the tail unit near the battery.
http://www.bikepics.com/pictures/1963709/
Anyone had any ideas what else could be wrong? I checked the fuse in the above pic and that was fine too.
I'm a bit new to this 'fix the bike myself' type of thing so any help will be much appreciated.
- skinnydog0_0
- Bike owned: Penny Farthing
Re: Little bit of help with dead NC30 please
Hi,
What voltage do you get across the battery when you try to start the bike?
dannyw35
The voltage readings when I try to start the bike normally dips to near 0.skinnydog0_0 wrote:Hi,
I'll have to try it again at the weekend and will post with more accurate figures.
- skinnydog0_0
Hi,
i think your battery might be shot, it should read at least 10.5v when you have a load on it. try looking at this site it is quite good.
www.mcnews.com/mcnews/articles/battery.htm
If you have a spare battery might be best to try it, also might be worth checking if the regulator is working properly.
- NGneer
i think your battery might be shot, .
dannyw35
Thanks for the replies.
Can I just take the one from my R6 and see if it works?
I hope it is just the battery!
- skinnydog0_0
I dont see why not, if it fits?
Do you have a manual to show you how to test the regulator/rectifier?
Because if the regulator/rectifier is knackered then you dont want to damage your other battery buy running it for to long.
dannyw35
Thanks - the plan is just to hook it up and see if it works - don't intend on leaving it in their...skinnydog0_0 wrote:I dont see why not, if it fits?
Now...how do I go about testing the reg/rectifier? Bit of a noob at all this...thanks
- skinnydog0_0
set multi meter to 0-20v dc connect+ probe to red/white and - probe to green turn on ignition on, and you should get full battery voltage.
next
switch off ignition, set meter to ohms check for continuity between green and earth.
next
check resistance between any 2 yellow terminals should get between 0.1 and 1 ohms
if you don't get the results above you will need to check wiring between battery and rectifier.
if the wiring is ok, probably a faulty rectifier.
If you plan to do any work on the bike yourself, it would be well worth getting a haynes manual there is more info in there about the resistance reading you should get testing all the connections on the rectifier.
hope this helps
P.S. i am not an electrical expert, and i am sure there people on here with far more knowledge about this that could give more/better advice.
next
next
hope this helps
- NGneer
Dannyw35 - you got mail!
