NC30/35 downpipes - interchangeable and collar dimensions!
- DoktorMandrake
- Bike owned: NC35 & NC30 x3
My mate needs a set of downpipes for her NC35 as her collars have rotted. (Incidentally, I wonder how much money Mr honda saved by using mild steel collars? Crazy bastard) I was thinking I'd just get stainless collars welded on my old set of pipes for her. Question: will my old NC30 pipes fit her NC35 and what dimensions do I need for the collars? Anyone know? Thanks!
- DoktorMandrake
Re: NC30/35 downpipes - interchangeable and collar dimensions!
Bump...
Anyone know if NC30 pipes fit an NC35? That would be a start...
Old Painless
Could you take the existing collar off and have some machined the same size and welded together round your existing pipes ?
Yes they'll fit - the same front pipes and slightly different rears.
The only issue is that the sidestand ight touch the pipes...no biggy
No idea on dimensions - it is on here somewhere though..so get a search on for it..or PM rcv4 as he has the pipe skills and has done a few replacements..
- DoktorMandrake
Thanks peeps!
Old Painless - the existing collar is dust, mate. Rotted to nothing.
CMSMJ1 - thanks mate. have dropped rcv4 a pm. Will also attempt to find the dimensions on here.
Morespeedvicar
You could measure the O.D. of your downpipes and add 0.5mm and get some stainless pipe that size. i have some in the garage which i will measure up for you tomorow and post up if it helps. Cant help much about the length tho, i think off memory i made mine about 40mm long.
Ian
Ian
- DoktorMandrake
Hey Ian, I'm not much of a welder or I'd have that pipe off ya. Contacted rcv4 who's going to hook me up with some collars. Thanks though, mate. Appreciate the offer.
