Gk76 fork question??
Johnny
Post by Johnny »
Does anyone know what other forks fit the gk76?
I've heard the rgv usd's do. What about the gsxr 750 forks?
Variablevalves suck
Re: Gk76 fork question??
Post by Variablevalves suck »
Hi J,
Im not sure how close the spring rate and damping on the RGV's are but they are very close and use the same wheel, discs and calipers, so fit. The 750 will have the same yoke mount diamiters but i do not know about the lenght and im sure the 750 had 310mm discs. What year 750 are they? i have a list of disc sizes, so can check.
Johnny
Post by Johnny »
what's your thoughts about swapping the internals from gsxr forks to the rgvs.
So from what your saying thr rgv forks should fit straight in and use the same wheels and discs?
I was looking at forks from the srad and model before. They look similar.
Variablevalves suck
Im not 100% to give you an answer regarding the rgv, but they share a lot of parts. The 750 Srad is showing 320mm discs on my list so you will/would have to start swoppin wheels and discs.
Variablevalves suck
If you want help with disc sizes use the link below and under catalogue- enter the bike and all the sizes are there. :peace:
http://www.metalgear.com.au/index.asp" onclick="window.open(this.href);return false;
NOSfearatu
Post by NOSfearatu »
I believe not all rgv forks fits.
asked a guy on ebay whos sold one but the diameter of top and bottom yoke was not the same..
diffrence in years maybe..
Johnny
Post by Johnny »
I have now picked up a pair of forks from a member on here.
My next thought is swaping over the SP internals to the standard forks.
Any thoughts?
stripes1976
Bike owned: 6 gk76a's, nc29
Post by stripes1976 »
all fits just make sure you use new bushes and seals if your swapping parts :peace:
Johnny
Post by Johnny »
As a I cant find a fork guide for the 76, can someone tell me if the fork bottoms be swapped over, ie just swap the stancions?
stripes1976
the tubes unscrew from the bottoms but need a little heat to undo
