flat/fluffy spot
hmplant
- Bike owned: 85 GSXR7/11, 06 Bandit 12
flat/fluffy spot
started the NC30 up today & after it's warmed up it seems to die out when revved between 3-5k. my son says this normally happens but he dosen't notice it when riding
hmplant
Re: flat/fluffy spot
Can the carbs be balanced at home? have they got the little spouts on each carb where the tubes fit? I've got a set of guages & tubes
Have you got some take-off adapters? the hoses fit onto the cylinder heads, you remove a blanking screw and screw in a take-off adapter and push the pipe on that.
hmplant
ok thanks, what size are these take off adaptors? cheers
http://www.carbtune.co.uk/carbaccs.html" onclick="window.open(this.href);return false;
You can see the take-off adapters there.
They do plastic or brass.. brass are harder to break but iv'e never had a problem with either.
Honda use 5mm iirc.. someone else should be able to confirm
hmplant
ok thanks Neo, i think i have some of them
don't know if it'll cure it but worth doing anyway
cheers
