renthal rear sprockets question
Dynamohum
Post by Dynamohum »
can anyone tell me which way the rear sprocket fits :?: fitted mine with the stamped side out it came without instructions so asumed the face with the sticker and size faces outward am i incorrect :?
Polisher
Bike owned: z1000a1h, vfr800vtec, nc30,
Re: renthal rear sprockets question
Post by Polisher »
davethetrucker wrote:can anyone tell me which way the rear sprocket fits :?: fitted mine with the stamped side out it came without instructions so asumed the face with the sticker and size faces outward am i incorrect :?
You're bang on Dave
Writing and sticker face outwards.
Dynamohum
Post by Dynamohum »
Writing and sticker face outwards.[/quote]
thanks polisher, just changed chain as other one was an ebay purchased racelink chain and appeared to have a tight spot which gave problems getting tension spot on. after changing it to a new rk x ring i seem to have the same problem noticed slight wear on the outside edge of the sprocket teeth [ only done about 500mls] i am sure g/box sprocket is right way round so problem could be rear hub/bearing possibly.
banoffee
Post by banoffee »
so does the lip face in or out?
Dynamohum
Post by Dynamohum »
banoffee wrote:so does the lip face in or out?
thats what i was unsure of the flat side has the size and renthal sticker on it so assumed it was the outward side and the lip side inner :?: if fitted wrong way would give alignment problems as i noticed slight wear on the outer side of the teeth , going to remove sprocket carrier as i think i may have stupidly fitted thrust washer on the wrong side which may be my problem :oops: i have both washers between hub nut and hub does the thinner one go behind the sprocket carrier :?:
royster81
Post by royster81 »
they offset towards the wheel, lip inside.
banoffee
Post by banoffee »
guess whose was on the wrong way round :?
now sorted, got to be good for another bhp or two at the back wheel :grin:
brooky
Bike owned: cbr400,vfr400,crf250,ktm200exc
Post by brooky »
lip inward, assuming you havent got a 750 rear wheel?
Vinylmark signs - for all your bike, car, van, vinyl needs, one off tshirts also printed.
http://www.vinylmarksigns.co.uk" onclick="window.open(this.href);return false; email sales@vinylmarksigns.co.uk
Dynamohum
Post by Dynamohum »
thanks fellas it was on lip to inside all ok that way, was unsure so thought i would ask the bretheren . changed hub/bearings sorted thanks :grin:
