starter motor not working
triton
hi,had a bit of a problem starting the nc24 sometimes had a whirring noise engine not turning.try again after couple of seconds motor started no problem.tried it today press button ign and neutal lights go dim nothing happens.charghed battery lights bright same problem just dims lights starter dosnt turn any ideas
MexicanGringo
- Bike owned: '30
Re: starter motor not working
If the starter's gearing is getting jammed, itl cause it to stall,draw huge current and dim your lights.. One way to see whats going on is to open the right side of the crankcase, theres prob 10 -15 bolts around the cover. The starter shaft comes through on the right hand side on an nc30, maybe same on 24. Theres a gear between the starter motor and starter clutch(timing marks stamped on it), remove this gear and remove the starter motor and check for obvious damage. Theres only a few bolts to check all this so its not difficult
triton
i bump started it and it still failed to turn starter so i dont think it jams as that ussually frees jamming.
Is the motor spinning but not turning the engine?
You'll need to check under the casing and see if the splines are knackered or the gears that connect are working - that would be my best guess.
If it is trying to turn the engine and stopping them you have other issues...but probably related to the idelr gear that takes the load from the mtoor to the engine.
triton
i cant hear anything when i press starter button no whirring or clicks just the warning lights dimming
MexicanGringo
- Bike owned: '30
Remove the starter from the crackcase, just 2 bolts to undo on the starter motor then slide away from case sideways. Keep it wired and see what happens when cranked. if it does nothing then its most likely burnt out, you'l need to look inside crank case to find out why
make sure the starter motors earthed too when you try and crank it over.
triton
problem sorted solinoid replaced£9 now i can hear the roar of the V4 thanks for your help.
