NC30 Problems with Cylinder No's 2 & 3
davidc
Post by davidc »
My bike starts but is not running properly on cylinders 2 & 3 - have sprayed WD40 on the down pipes for these two cylinders and they're definitely not at the same temperature (they're colder) than cylinders 1 & 4. Cleaned out the carbs but the problem persists, I've also tried fuel down the carbs of cylinders 2 & 3 but it made no difference. Is it likely to be the plugs?
Any advice gratefully received.
Re: NC30 Problems with Cylinder No's 2 & 3
plugs would be a good start ;)
You can swap the working plugs to the dead cylinders and see if the problem is reversed 8-)
Welcome to the site.. :mrgreen:
Cammo
Post by Cammo »
Chucking fuel down the cylinders can quickly kill the plugs if they weren't dead already!
2 & 3 (Front Left / Right Rear?)
There fed by different coils right? In that case its not likely to be coil / plug lead issue.
As already been said though, plugs are fragile, so a new set first.
