petrol leek
Vfr400nc30
petrol leek
ok just after christmas i had a leek thought it was petrol but couldnt work out what it was petrol was still full, oil had gone down from max to min so thought it was that, then checked my coolant level and it was empty so topped both of them up and now they are fine and the bike was running fine although it hadnt been riden, so now im confused, but for the first time since it happened, last night i left the petrol on reserves and got up this morning to an empty petrol tank any one got any thoughts would be much apprecaited thanks
Christoph
Re: petrol leek
Not entirely sure what you're saying. You've lost some fuel but you cant see a leak?
VfRTeddy
- Bike owned: Vfr400 nc24
Re: petrol leek
was there petrol all over the floor if not it may have all gone into your oil happened to me had a hole in the tap diaphram
Ben
Ben
Vfr400nc30
Re: petrol leek
sorry like i said bit confusing
there was fule on the floor yh
at first it thought there was a hole in the tank now im presuming it must be a hole in the pipe but im a real novice dont know a thing my cousin knows everything about the bike as it used to be his but hes really busy all the time so can never help me
dont worry if you cant help guys
VfRTeddy
Re: petrol leek
then yer check all your fuel hoses even the 4 that split from the main one and go to each of the carbs bit fiddly if one has come off. and then check that it isnt leakin from around the tap cause the gasket could have been damaged or leaked from there hope that helps
Ben
Ben
